rd400e exhaust chamber pipe blueprints
Started by joseimport, February 04, 2020, 12:10:35 PM
joseimport
i have the original 2r9 pipes and headers for my rd400g.
which is the same as the uk rd400e. but looks like a daytona.
i need to restore the pipes, or buy new aftermaket pipes.
the bike is used in the street, so no race pipes
jim lomas pipes wont fit this bike, DG i have heard are not that good.
where can i have my pipes rebuild, (remove dents and rechrome)?
where can i find good aftermarket pipes?
does anybody have a blueprint for pipes?
1975 cb750k2: ongoing restoration project. http://forums.sohc4.net/index.php/topic,183427.msg2122966.html#msg2122966
1979 rd400g daytona special: started putting it back together. http://www.2strokeworld.net/forum/index.php?topic=71.0
1987 tr200 fatcat: running.
racerclam
Gary Braun builds very nice pipes  612-913-2411  tell him Rich  from richstaylordporting sent you
Rich
bitzz
If you want to pay the postage;
Buy a pair of GRA2stroke pipes. One of the best RD400 street pipes available.
Ship them to me. I'll modify them for a 3J7 and send them to your sister.
joseimport
#5
Quote from: pdxjim on February 04, 2020, 05:08:06 PM
Spec2 and GRA2strokes build great pipes for RD400E/F/G
http://gra2strokes.com/
thanks i already sent them an email. waiting for their response to see if they can adapt their pipes to my rd.
bitzz
...yeah there's a story that goes with that last post....
Jose: I found a pair of DG pipes you can have for free if you want them.
joseimport
Quote from: racerclam on February 04, 2020, 05:43:20 PM
Rich
yes i chatted with him, he could custom make the pipes, but at arround 1200usd, i think they are overkill for my future use.
i bet they are worth the money, but he specializes on racebikes. his instagram shows his work, check it out, good stuff.
joseimport
Quote from: bitzz on February 04, 2020, 09:04:44 PM
hey jim how are you?... i tried reaching you by email a year ago.
you sent me the original 2r9 pipes and headers, which are in good condition. but need a little work.
some dings need to be removed.  and they have to be rechrommed. when you sent them to me i should have left them in miami. so they could be rebuilt in the USA.
i have them here in Colombia, but i dont trust any of the shops here to touch them.
i bet they would work like they are. but i have to make this bike justice and restore the pipes.
i´m looking for a good shop on Florida than can clean them (i could probably do this and save $$), remove old paint (they are painted over in black) remove old chromme (i could probably do this too), then rechromme them with a cooper-nickel-chromme process.
so if anybody knows let me know.
Have you considered ceramic chrome coating a lot cheaper, I know a couple of good shops in central FL that do that. Chromer will charge big $ just to clean inside of used pipes to avoid contaminating their tanks, before the big $ to chrome.
These keep center stand routed like stock,--- https://www.samurider.com/?p=29127/#itemImage -- they have other styles that retain center stand. --- https://www.samurider.com/?cat=207
joseimport
Quote from: RDFL on February 07, 2020, 11:06:38 AM
yes i thought about it, there is a cerakote dealer that can cote it here in colombia, but i would rather chromme them.
when i get to that point i´l make the desicion.
any sugestions how to clean 40 year old carbon deposits?
Quote from: joseimport on February 07, 2020, 05:07:03 PM
Radiator shop hot tank.
I once welded a large washer (just small enough to fit through front end of mufflers) to a piece of conduit pipe, then ground the edge of the washer slightly tapered. This was then used for scraping off carbon deposits from the muffler walls from the front end to the first baffle plate. Then I used a turbo nozzle wand on my high pressure washer to knock out some more carbon deposits. A high pressure sewage unblocking nozzle may be useful for cleaning aft of the first baffle plate, although I never tried this myself (these HP nozzles have 3 or 4 jets pointing outwards and backwards, propelling them forwards through a blocked pipe)
joseimport
anybody knows a good exhaust restoration shop in florida?
i need to clean, remove dings, and rechrome the original pipes
