Powerdynamo question rd400
Started by rd400greenhorn, April 27, 2020, 03:31:12 PM
rd400greenhorn
Hi guys
So i have this ignition iam gonna try to install in a few weeks..
My question is
Do I use this Kit and NOT the rectifier i have got -( this alu housing with cooling fine)?
Because it says in the powerdynamo Kit it comes with a reg/rec
Sorry but Its Very new to me
use the one that comes with the powerdynamo
fair question though.
Tuck
Don't forget to run your neutral wire thru the wire loom. :whistle:
rd400greenhorn
I have run a neutral wire through 👍 but just read and looked at the papers with this ignition unit
Seems as I bought a reg/rec not knowing one different came with the Kit
At least different looking then this with cooling fins
rd400greenhorn
Can anyone confirm this?
Use the top one, without any fins.
rd400greenhorn
yup. non fin is newer one, should have the capacitor in it.
:metal:
Frank B
Take your time with the install, it's easy really. I think it took me longer to remove all of the old system then it did to install the new.
You'll have to remove a small bit of the case and some from the back side of the side cover to get it all to fit but it's really not bad. The instructions mention some of that.
