Crank in rd400 Does this look right
Started by rd400greenhorn, March 02, 2019, 02:52:59 PM
rd400greenhorn
Hi guys
Iam finally in the proces of fitting the crank, the pins fit now
Stupid question but everything is a First
Does this look right? Seals Are located correct, right way?
Cheers  :patriot:
Springs always face the outside. So, I'd say yes. :)
Also, make sure to put a little 2 stroke oil on the lips of the seals.
~JM~
Are the steel bearing alignment rings in place? Can't tell from the pictures.
rd400greenhorn
The two cases Are together and done 😁 Hopefully Iam doing it right  :vroom:
