Fitting v force reeds in rd400 cylinder
Started by rd400greenhorn, March 03, 2019, 08:16:34 AM
rd400greenhorn
Yes
Any tricks to it? Or is it dremel until They go in?
rd400greenhorn
Well it still requieres to grind the intake.
I have a 10mm spacer
yup. also make sure you clear enough out to clear the petals when they are wide open.  I assume those are the YZ85 reeds
Tuck
#4
Get some of these if you don't already have. Take your time!
http://powertoolsgroup.com/details-Hthgvu/87-4.html
rd400greenhorn
I have something similar to those, for my dremel.  :patriot:
I have those, they cut fantastic. I also use them on my 1/8 pneumatic grinder. :righteous:
rd400greenhorn
So i Will grind, test fit, and grind some more, until They go in easy? :)
Yes They Are yz85 reeds :metal:
Quote from: rd400greenhorn on March 09, 2019, 05:49:28 AM
And use 4 pcs of long M6 bolts as guides when test fitting, as someone (Chuck?) described in an earlier thread. Run the long bolts through the reed block, and screw them into the cylinder. That way you can be sure the reed block is properly centered in the reed cavity when test fitting.
