Deals Gap Shenanigans
Deals Gap 2-stroke meet 2024 : May 5-12th.  25th year!
Clutch Slip
Started by peaky, July 01, 2020, 10:05:36 PM
peaky
I've upgraded my Kawi S2a to the point where I get noticeable clutch slip on hard acceleration. Bigger carbs, flowed engine, Jim's pipes, Boyer ignition. Friction plates are all within spec. No glazing on steel plates.
Want to try a different set of clutch springs. Suggestions? Thank you!
fit an s3/k400 clutch basket and primary, ive been down this road with s2's.
peaky
How is the S3/KH4 clutch basket different? Domo wants to know.
Holds more plates. Use new fibers and stock springs. I put the late H2 ball bearing actuator in my S2A as well. As stated above you need a 400 primary gear.
^ Tim was the one who actually suggested it to me .  it def made a big difference.
peaky
OK! Thank you! Guess I'll finally use some of that spare gasket set I bought back in 2004.
