Rd400 led headlight stock wiring
Started by rd400greenhorn, July 13, 2020, 05:23:48 PM
rd400greenhorn
Hi guys
So, considering to change the headlight, but when stock every wire up front connects in the headlight, by question is this
Has anyone ever relocated All that wiring and or how, if the new headlight was sealed, ergo No wiring goes in it.
Hope you get My question :)
Cheers
sure.
made a new harness from scratch.  :cheerleader:
You end up with a bit of a crows nest of wires up front.  Get some good bullet connectors and cut all the wires as short as possible.
I put duel LED lights on mine with an digital speedo, and I have had some electrical gremlins so the wiring has been dug apart a few times and definitely needs some tidying up. I made my headlight mount and speedo mount  to try hide some of the wiring, and plan on using some closed cell foam to block off the rest.
