Running tm34 on my rd400 problem
Started by rd400greenhorn, July 19, 2020, 07:23:33 AM
rd400greenhorn
So i got tank on just to start her up and go ride to test the gears
Its got the old oem fuel petcock on, fitted with industriel 6,4mm ( 1/4") fuel lines
Does it get fuel enough or is 1 liter of fuel in tank just not enough for consistent start?
rd400greenhorn
I mange to get it to run so what with choke on,  plus the left carb is leaking underneath somehwere.. Cant seem to find the problem with that carb. Had it open 2 times now
Float height? Float needle?
Try to find where it's leaking from.
rd400greenhorn
Yeah so iam not sure how and or where do adjust this, allthough the float sits on 1 metal rods, and they seem to slide easily
ElFuegoBlanco
There should be a tang on the float that sits on the needle. Bend the tang up or down as necessary to get the proper float height.
The float height is important as it will stop the flow of fuel before it overflows out of the carb, but also allows enough fuel flow to not starve the motor.
I'm not familiar with the VM34, but it should look similar to this.
rd400greenhorn
Seizer
When I upgraded to TM34s, I also got the Raptor 660 upgraded Petcock from Chuck. Also went to all 5/16 fuel lines.
rd400greenhorn
Yeah so did I.
But when removing the fuel line from it I pulled out the one fuel connection ( brass?)
Not sure what do fix it i put a oem petcock on
at the end of the day, you need to size it for total area of needle seat(x2) vs total area of petcock opening. that's really what it all boils down to.
sounds like you had debris behind the needle at the float valve.
as far as the petcock, you should be able to press the fitting back in.
:twocents:
rd400greenhorn
Yeah, though Its just a bit to easy to put in or take out.. Might need some strong glue /locktite
Yeah gonna have to adress the total fuelling system on it
On of my carbs also did that. I scuffed up the end of the brass fitting and put it back with a little bit of JB weld.
I adjust all the big TM carbs floats down some as with the big petcock conversion and the stock 3.3 needle valve size they don't need to be so high like in a wide open throttle dirt bike!
Float height is just a crude proxy for fuel level and that's what's important.  Ask Evans Ward if he has a fuel level adapter for your carbs and set fuel level initially 3mm below the gasket surface and work from there.
If not, get a float bowl bottom nut from a snowmobile with a water drain and use that.
rd400greenhorn
So have both carbs hanging of the bike
Buttombis taken of, everything looks similar, flot height membran? The one you can adjust up and down is both equal flat?.
I think the one side thats leaking, the floater maybe dont love so freely.
:umm: :umm:
