Mat Oxley 1986 IOM TT
Started the Hybrid build
Started by dusty350, July 27, 2020, 02:51:11 PM
dusty350
Frame just back from powdercoating, so I can start adding the parts I've already refurbed;
20200725_165023 by dusty miller, on Flickr
Wheels went for coating today, so hopefully have a rolling chassis in a couple of weeks.
Dusty
Wow that is simply bike porn!  :nana: :bacon:
Now I really feel like a beginner "TURD"
sav0r
Now that is pretty. :swoon:
Are you putting that dry clutch beautiful engine in there?
toffee
dusty350
When it's up on it's wheels, the engine is ready to go straight in. Still a lot of parts to source, and all the paintwork to get done. I did a twin tap conversion on the tank to do away with the rubbish cross over tube at the front underside. The tail cowl needs cutting too as I plan on recessing the tail light with a bespoke bracket that I have a template for. Building a bike from just a frame is a ridiculously expensive way of doing it !!
Dusty ;D
mavguy
toffee
Quote from: dusty350 on July 30, 2020, 01:32:08 AM
...... Building a bike from just a frame is a ridiculously expensive way of doing it !!
Dusty ;D
Tell me about it!
Next project I will at least start with an almost complete bike.
Going the Hybrid route also adds a lot of expense.
Plasticman
What forks did you use on this project?
Rob
1976 - RD400 - road racer
dusty350
Hi
It's an Rgv front end with billet yokes to suit the Rd headstock and Rgv forks. You can use standard Rgv yokes - you would just need a 5mm spacer underneath the lower taper bearing on the stem to get it to work. The billet yokes have adjustable lock stops - the standard yokes would need them re siting for the Rd frame. It's up on it's wheels now;
20200811_130034 by dusty miller, on Flickr
20200811_131455 by dusty miller, on Flickr
20200811_130049 by dusty miller, on Flickr
Dusty ;D
Plasticman
dusty350
Engine in today :toot:
20200812_142125 by dusty miller, on Flickr
And her stablemate got a glimpse  too;
20200812_142536 by dusty miller, on Flickr
;D
bostontrackrat
Fantastic work! It looks great!
Where did you source the stainless head bolts?
