RD250b Vape Install
Started by toffee, August 26, 2020, 02:59:30 AM
toffee
#17
Quote from: rodneya on August 26, 2020, 10:28:33 AM
This is how I wired in my kill switch on my 350
Thanks redneya, im not sure this will work for me, i have 2 wires from
the kill switch, red/yellow to main switch and the red/black.
Quote from: quocle603 on August 27, 2020, 08:09:39 PM
I followed the same diagram for my HPI ignition. Your power (black cable label SW) should spliced the power source of the coils Red and White on the RD400 and Red and Black on RD350. I used one of those quick wire splicer to do this.
thanks for the info quocle603, i think part of my problem is that i dont know
where the red/black wire from the kill switch should go now that the stock
coils are not there. I have connected the black from the relay yo the red/black
but no "click" when ignition on.
Red and yellow from the kill switch is connected to switched power from the ignition
this is what feeds power to the red black to the relay.
If the red yellow is not connected you wont have power to the relay.
toffee
Thanks again, did some tricking around with the electrics,
the relay is now clicking on and off with the kill switch....
and also when the brake is applied when on switch position II  :umm:
