Mat Oxley 1986 IOM TT
Flat spot before the powerband.
Started by quocle603, September 04, 2020, 10:47:22 PM
**Update**
I was able to test ride the bike without the Y Boot with the single K&N filter. It definitely helped my throttle response with the extra amount of airflow. The flat spot is much better but I will mess around with my needle positioning to see if it improves anything.
**Update**
Changed the needle position to position one and it helped it a bit more with the throttle response but it's still a little rough between that 5-6k gap. I will see what I can do with the transition to my mid range.
this is where reed spacers may help a bit.
Thanks for the tip, Mark. I will look into this. Be cool if I can use some high temp filament and 3D print some.
that, unfortunately,  would be a negative.  1/4" aluminum plate or the ones john sells at economy.  :twocents:
I was gonna ask my buddy to cut me some with his plasma table, I saw that John was selling 9mm ones but 1/4" (6mm) would would as well?
I was just pulling your leg about the 3D printed parts, still going to try to make those expansion chambers though!  :dawg: :dawg:
Just got some 1/4 inch steel spacers made by my buddy. Simple 2 min cuts from his plasma CNC machine. I will be putting them on my RD tonight.
smokah
Any update with the spacers installed?
Sorry, Dino. No major updates. I have been working on my Suzuki T-500.
It seems like it has helped it a bit, but I would need to rejet my carbs. I think I over shot my pilot jet (i went up two steps) when I installed the spacer. Riding season is almost over, so I would need to jump on this.
