Oil Pump Injection Nozzles
Started by Diablo007, September 17, 2020, 01:04:46 AM
Diablo007
The oil injection nozzles I have fit loosely in the carburetors.  One side is OK, but still looser than I would like.  The other side is loose.  What is the best way to seal them?  RTV silicone?  Yamabond 4?  Any tips would be appreciated.
2 stroke junkie:
Barto
Judging from what I put in my amazon cart so I would remember, Chuck says Loctite 640 High Strength Sleeve Retainer.  Hopefully someone better at searching the site can confirm.  Posted this year, I bet.
'79 400F                             '82 KZ750E
'79 Husqvarna WR390          '70 MTD minibike
'77 Husqvarna CR390           '55 Indian Woodsman (British 500 Bullet) basket
'75 Bultaco Alpina 350
'66 Benelli Cobra 125
Yamaha recommended contact cement.
The locktite  will work if you have it, or use JB weld
Barto
  Wow, thanks for all the rebuilding of the Tech Library, SoCal250!    :whoop:   I better check more often and work on my search skills!  Super appreciate both, Thanks!
'79 400F                             '82 KZ750E
Quote from: Barto on September 17, 2020, 08:59:21 PM
:thumbs: It's a little Yamaha heavy but it's intended to be our go-to resource for specs and other info tidbits.
Diablo007
Thanks!  I guess my search skills need some honing also.  I thought I had checked the Tech Library but apparently not good enough.  Now that I see the link to the green loctite solution I realized I had read that before this bike was back-burnered.  Fired it up today and it was awesome.  First engine I have totally rebuilt.  Well, I left the oil pump alone as I have been told many a time that they are bullet-proof.  (Here come the comments....)
2 stroke junkie:
I use locktite green for all my brass carb parts that come off
rd400greenhorn
Where do you buy new nozzles thwt fit stock rd400 carbs?
yamabits, economy cycle, hvc cycle.
klaird
Economy gives forum members a 10% discount.Use coupon code 2SW
