Question on RD400 Pistons
Started by KANDY, October 06, 2020, 11:03:28 PM
KANDY
Hi All,
Quick Question to confirm. Can I use RD350 Piston on 1977 RD400
Thanks
1974 RD350
1981 RD350LC
1977 RD400
1980 RD400 Daytona Special
Yamaha 179
Yes you can.  You might want to think about it a bit, i.e., you should match brands and types as much as possible to minimize possible problems (except in an emergency) but they will work.
Lyn Garland
KANDY
Thanks Lyn, Got a deal on RD350 Wiesco second Oversize.
It does not have the cut on the exhaust side, does that make any issue.
1974 RD350
1981 RD350LC
1977 RD400
Yamaha 179
None at all; in fact that is better.  You know forged pistons require more (looser) clearance, right?
Lyn
KANDY
Yes, I will maintain the specs needed for Wiesco.
Thanks again Lyn
1974 RD350
1981 RD350LC
1977 RD400
I'm confused...Aren't RD350 pistons smaller than the RD400 cylinder bore?  :umm:
Quote from: quocle603 on October 07, 2020, 02:26:48 PM
Both are 64mm bore
Diablo007
Longer stroke on the RD400.  RD350, RD400, and RZ350 pistons are basically the same; though the tang' on the RZ350 piston needs to be removed before using in an RD.
http://www.greasygringo.com/2012/03/using-banshee-pistons-in-your-air-cooled-rd350400/
Can the RD pistons be used in an RZ350?  Never thought about that as RD pistons seem to be the ones that are hard to source nowadays.
2 stroke junkie:
Quote from: SoCal250 on October 07, 2020, 02:28:56 PM
Both are 64mm bore
It's the stroke that makes up the extra 25cc's in each.
Quote from: Diablo007 on October 07, 2020, 02:36:08 PM
Rd windows are smaller than the RZ / Banshee pistons, so it would be a downgrade
Diablo007
@rodneya
Thanks for the info.  Seems I oversimplified things in my mind.  There are differences in design beyond the 'tang'.
2 stroke junkie:
Thanks for clearing things up for me. I did not know that! I've always thought that the bore was overall bigger.
I've done this. Works great with my build...
