Introduction. I'm new, sort of.
Started by Inov8, December 27, 2020, 11:01:03 AM
Inov8
Hello everyone and Happy Holidays.
My name is Allen and I live in Ormond Beach, Florida. I registered for this forum the other day but I've been lurking since the site came back up. I used to belong to the old forum, I think, but I mostly read and don't do much posting. I'm 52 and have been riding and working on bikes since I was about 14. Over the years I've owned an S3, 3 RD400s and an R5; as well as, a Harris TZ250 framed, RD400 powered street bike that I built in my shed (I'll try to find pics)  I've always wanted a 350 and for Christmas this year my wife got me the bike shown. It's mostly stock except for a Vape ignition, pipes and heads. It runs ok, but has 400 heads and the Vape is not timed correctly. This bike will be the subject of a build thread; my goal being a total sleeper on the street and something different to ride on track days.
Arrow
Welcome in. Nice project.
suey1958
Welcome, Very nice Christmas gift indeed ! Looking forward to your build thread.
Welcome :cheers:  Congrats on the new bike. That's a great gift! (The wife is definitely a keeper!)
Are you certain the heads are for a 400? The only way to tell is to look for the stamping on the underside of the fins. The DGs for both the 350 and 400 are the same dimensions, so they will have an overhang on the 350 engine. In any case, it's best to get them recut for proper squish and today's fuel (and decked for a 400 type gasket or cut for O-rings).
Looking forward to watching the progess.
Great bones to start with.
Like SoCal said,  pull a head and see what they are stamped.  Mine were 400's, cut and corrected for a 350.  Thankfully restamped too.
If you send those heads out go for the o-ring option, I wish I did...
Is that the one that was on CL recently?
Nice to meet you and welcome aboard! I like your 350 and look forward to your build  :thumbs:
Inov8
Thank you all for the welcoming and the tips. I like this forum because of everyone's willingness to help out. I only had the bike a few hours before I had to investigate why it had no guts. My bone stock R5 was must faster than this bike. First was a compression check which showed a tick over 100 psi. So, I kind of suspected 400 heads at that point. But before I pulled one, I did a leak down test which checked out fine. I pulled a head confirmed that they are indeed 400 heads (see pic). Next, I checked ignition timing. I felt like the bike should run better than it did even with the low compression. Ignition was set at just under 1mm BTDC. Mystery solved. I could hear that something was off, even in the idle. An otherwise stock bike with just DG heads and pipes will still have a nice "crack" in the exhaust sound and a "ring" in the pipes at idle. This bike sounded muted and soft. Another clue was that it had no torque down low, as if it were a race ported bike. But, when it hit the powerband, instead of rocketing forward on one wheel like I was expecting, it just pulled slightly harder. I've already stared the teardown and will start a build thread soon.
JB Weld
Welcome back! Look forward to seeing your progress.
Greaser Greg
Welcome home and your input will add more  :bacon: to an already  :righteous: forum!  Thank you! :cheerleader:
