Motor running away at start
Started by patastinky, January 07, 2021, 02:15:20 PM
patastinky
When i kick start the bike it revs to the max. I have to use the OFF/RUN/OFF button to stop the engine from redlining. All my air and gas screws on the carbs are turned tight inward. 1975 RD350 stock
What bike is it?
By gas screw do you mean the idle screw? If that is screwed right in it will rev on startup.
Set airscrew at 1.5 turns out and idle screw so that it is just touching but not lifting the slide.
If they are vacuum tubes?? you need to block them off
do you mean oil injection lines or breather tubes? theres no 'vacuum lines' on rd carbs.
also make sure the slides aren't hanging up in the carbs for any reason. .02
Quote from: rodneya on January 07, 2021, 03:28:14 PM
What bike is it?
>>>>>>>>>>>>>By gas screw do you mean the idle screw? If that is screwed right in it will rev on startup.<<<<<<<<<<<<<
This.
patastinky
Quote from: Striker1423 on January 07, 2021, 02:49:42 PM
Vacuum tubes?
Oops. I don't know what I was thinking.
What bike is it?
1975 RD350
What bike is it?
Yes, Idle screw and the air screw on the carbs. I have mine turned all the way in. I thought that would be a good starting point.  I'll try what you said tomorrow. Disregard the vacuum tube comment. :)
Quote from: m in sc on January 07, 2021, 04:21:06 PM
Slides aren't hanging up. They don't go all the way down, but aren't they supposed to have like a crescent moon shape at when they are down (off throttle)?
NYSingh
Crossover tube connected?
Can you post photos/videos of how your carbs are set up?
Moto Guzzi V7III
Djg8493
Are you running oil pump or Pre-mix?  If Premix are the oil pump tubes in the carbs blocked off?
the front (motor side) of the slide should be able to hit bottom.
when the slide screw just touches, go in 1-1.5 turns and should be a good starting point.  :twocents:
airscrew starting point 1.25-1.5 turns out
patastinky
Quote from: NYSingh on January 08, 2021, 12:03:07 AM
yes, they are connected. Sure thing, I'll take a video :)
Quote from: pdxjim on January 08, 2021, 12:53:45 PM
Print this out for bathroom and before bed reading.
http://www.mikuni.com/pdf/vmmanual.pdf
This is awesome, thank you. Already started reading it.
Quote from: m in sc on January 08, 2021, 09:53:39 AM
is the "slide screw" the "idle screw"? and by "just touches" do you mean while "remove the screw, begin to screw it in and as soon as a thread catches, turn 1 full or 1.5 turns.
Quote from: patastinky on January 09, 2021, 01:34:15 AM
Yes by "slide screw" he's referring to the idle screw. Thread each screw in until the pointed tip just contacts the slide, then turn 1 to 1.5 additional rotations. If you're looking into the bellmouth of the carb you will be able to see the slide slowly rising in the bore very slightly as you turn the screw in.
