HPI ignition install
Started by turtle, March 24, 2019, 10:21:06 AM
2t Fan
Do they have a different kit for 73 RD350AB ? I mean since the rotor is held in place by a bolt not a nut like in later RD.s?
Just got mine yesterday. Does anybody have a rect. that they recommend to go with the trail tech regulator?
I will have to do a bit of research. Thanks
I'm leaning towards an HPI for my LC build.
I assume I to buy the "Ignition & Lighting" kit:  https://www.hpi.be/item.php?item=210K112
Do I also need the CDI: https://www.hpi.be/item.php?item=CD4308
... and the R/R?: https://www.hpi.be/item.php?item=CD4308
Please forgive my rhetorical/dumb question ... I'm in the dark about mc electrical stuff.
the seperate cdi you listed is for a stock bike. just buy the main unit (1st link) and you can use their rr.
Djg8493
FYI, I just got the email on the Treatland Flash Sale
18% off use code "pumpkinspice" sale ends 10/25/2019
Just about to let people know this too! ^^^
How's this look for a coil mount?
turtle
that is where I mounted mine.. seemed like a good spot and should receive nice air flow.
hung mine right off the upper frame tube. however, ive done similar. don't leave it single shear mount, the bolt will eventually break.  support it on both sides if you can.
Yup a bolt on either side. Flange bolt, coil, spacer, frame, lock washer, nut.
Thanks
