HPI ignition install
Started by turtle, March 24, 2019, 10:21:06 AM
you running a battery?
IF i were to run a battery on mine with the hpi, id consider this. (but would require un-grounding the other end of the lighting coil)
https://www.trailtech.net/en-us/shop/accessories/motorcycle-parts/electrical/electrical-components/dc-regulator-rectifier-150-watt-full-wave-w-relay/
looks like an interesting unit. im running the AC regulator and love it.
other people have run this unit.
https://www.ebay.com/itm/4-Wire-Full-Wave-Silver-Motorcycle-Regulator-Rectifier-12V-DC-Bike-Quad-Scooter/292689887133
however, quite a bit has been discussed in the 'team scream' section on this forum under 'HPI install'.
Thanks for everyone posting in this thread! Helped me a lot, if you struggle with this installation then just re-read this and the Supertune thread.
rd350mississauga
Im trying to get the motorcycle running with battery. I bought the ATV 4 wire R/R from ebay.
I now have only 1 lead to the R/R, which is the HPI yellow "light out". How can i unground the coil, so I have 2 leads to the R/R. Also, how does this ungrounding affect the ignition voltage?
1975 Yamaha RD350B USA
1983 Yamaha RZ350K Canada
ungrounding the lighting coil has zero affect on ignition. :twocents:
you need to find the lighting coil ground, its a ring terminal held on with i think an m4 or m5 to the stator plate (so you have to remove it). then solder on a wire to the newly ungrounded wire, snake up up the harness to the rectifier and viola. there you go. look up 'floating the ground' on google, pretty common on ac bikes.
Quote from: m in sc on August 27, 2020, 12:36:16 AM
Yep, look at my post on the other thread. Its the allen (m4) that you take off. Make sure you tape off the silver wire cause it can be grounded. Remove the black pin from the CDI unit (3 wire connector) and you can wire that to your pink or yellow! BANG you have 12v DC from your RED on that ATV R/R.
rd350mississauga
#95
Installed the Rectifier+Regulator today.
I took a line from the black wire, close to the plastic connector near the CDI unit, to feed the R/R. I didn't run a seperate snake line from the stator.
Removed the m4 allen as advised and taped it up; to un-ground.
Got a steady output of 13.6V / 5A at idle. Finally found the engine kill switch wire and connected it to the cdi (picture attached, the red+black wire). Thank you M in SC, quocle603 and my brother for the valuable tips.
Glad to help!! Now start blasting away!
rd350mississauga
Can i use a non-resistor type spark plug with a HPI CDI unit?
Some says it will burn the CDI.
Some say it will only cause electrical interference with the CDI box and can be fixed by moving the CDI box away from the plugs.
I feel atleast 20% reduction in power with the NGK BR8HS resistor type spark plug.
20% reduction on power? no way I don't buy that for a second. If you are down 20% you have other tuning issues.
Its indetectible if anything, at best. try non resistor, if you -think- they work better and don't break up the signal, have at it. no permanent damage either way.
rd350mississauga
Does the coil end need to be grounded? (the thick metal square that looks like a battery terminal)
i dont think so. its just a mechanical mount.
rd350mississauga
Got mine in 2020. I guess it must be a newer model as the stator has a scale like timing mark in it. Each 5th mark equals 1 mm, was easy to play around to check power difference at different ignition settings. Tried between 1.8mm and 3.5mm BTDC, got the best power at 3mm BTDC. Finally used a dial gauge to recheck since I was following the scale on the stator and it was almost exact.
rd350mississauga
 :taz:Running into issues again. I am only getting DC 5V-2 Amp at 2000 rpm. Voltage goes up to 13.5V only after 5000 rpm. My battery cant keep up with it. Currently running a lead from the ungrounded end of the coil along as 1 input to the RR and the HPI supplied light-out as the other IN for the RR. These 2 go into the input of the R/R.
I even bought a trailtech R/R  (model 7004-RR150) which is a full wave 150 watt RR with a relay, suspecting that my existing ebay RR might not be working. Voltage is dropping as RPM increasing!  :shocked:
Any  help is greatly appreciated
