Whats in my garage
Started by busa1300, March 24, 2019, 06:11:25 PM
busa1300
#180
Quote from: m in sc on September 04, 2024, 09:33:14 AMoh man thats going to be a weapon.  :olaf:  :nana:  :metal:  :cheerleader:
:thumbs:
Hopefully not a weapon that kills me. :cheers:
Quote from: Rgvnfla on September 05, 2024, 03:53:46 PMHey Busa, thanks for the advice on my 400 top end . I changed up on the color and I got it all back together and presentable at this stage,I need to spend some time on my RGV. Your bike will be amazing! I may have some engine parts if you need seals and such.what ignition are you going to run?
That green looks really good with those decals...look like from a TM...?
Hope you get it dialed in good and can get some use out of it.
Sadly mine is not close to rideable yet.
On a completely different note...
I now have TZ250 rear wheel for my TZR after years of searching...and it came with a matching TZ front wheel as well. From a 1991 3YL with dimensions of 3.5x17 and 5.25x17 along with my TZ Brembo 282 rotors.
The search for parts is basically over...time to find time to rebuild.
Just need to have some captive spacers made now...
RZ350-RZV500R-TZR250RSP 3XV2
TS/TM400 supermoto style...
busa1300
Engine going back together
Been over a year since I split it apart  :shocked:
TM400 close ratio trans
New Wiseco piston
Ported TM400 cylinder
Holding 5 psi for over 15 minutes...
It's ready for some shiny covers and then the timing and wiring...
busa1300
After setting my Vape flywheel to get the TM spec 19.5 degrees....
Damn! That sounds good. Oughta be a hoot.      :taz:
busa1300
Quote from: dgorms link=msg=55854  date=1730501858Damn! That sounds good. Oughta be a hoot.      :taz:
 :thumbs:
It is considerably louder than the video might suggest...sounds good to me, but might get some unappreciative looks by those I scream past.
busa1300
#185
Closer to the finish line...
Sent chrome bits out to get refinished
Correct fitting original style turn signals are impossible to find (used only 2 years with just this model) so I adapted some from a T500
A new nos 12 volt headlight to replace the original 6 volt
New gauge housings and 7000 redline tach that now matches the speedo (had mismatched gauges)
Getting the beat and abused tank back in shape.
And tail light basically back to new...
Bike is ready for its fresh bodywork, after I get tank sanded down and ready for the original styled decal, then cleared one more time.
Select hotlink for forums rather than thumbnail
ive never heard one that crisp. man. thats nice
busa1300
 :thumbs:
I think it's bark will be just vicious as it's bite when moving to the upper end of rev range.
Definitely likes to fight while trying to kick it over.
busa1300
Almost done...almost...
Before and after...after almost two years since the start...
Excellent work Randy! :thumbs: That's a beautiful final result. :nana:
RDryan
That is a very stunning resto mod of a bike. I envy those rims I would love to replace the stock rims of my RD250B with some of those excel aluminum rims or something like them.
I imagine that iteration of that bike feels a lot more lighter and nimble than as stock.
TeeZee
With all those strokers in the stable and the mighty Busa, you're not only living the dream most of us have but making us jealous at the same time.
Thanks for bring them alive and on road. All the hard work that goes for each step pays off but after much needed perseverance.  :patriot:
busa1300
#194
:thumbs:
Thanks for the kind words guys.
It's a struggle to keep them all running all the time. And restraining myself on what to change and what to keep as original.
The TM/TS has had a few short trips down the road, but still trying to get jetting reasonably close before I take it for a real test ride.
I really hate the tuning part of dealing with 2 strokes.
With tank emblems, and ready to run.
It will never be as clean as it is right here....
