Original rd400 carb assembly
Started by rd400greenhorn, February 28, 2021, 06:36:29 AM
rd400greenhorn
Hi guys
Is this right - that half moon, does it sit correct direction?
Alain2
rd400greenhorn
Yamaha 179
That's the correct direction but, if the carb is stock, it is not the correct Needle Jet (Nozzle).  Have the carbs been modified?  That is a primary Needle Jet and the 400s come stock with the bleed style jet.
Lyn Garland
rd400greenhorn
Ah okay!
Can it run with anyways?
Its a mix match of carb parts, did not notice. They are both gonna run oil injektion
rd400greenhorn
I have maybe 10 sets of carbs and some were modified. Might have been from that
Alain2
You need to check what nozzles they are, they might not be adequate for your setup.
rd400greenhorn
So i assume i need to change that nozzle to a stock as the carb w. Choke?
:umm: :whistle:
Alain2
You need to check the numbers stamped on both nozzles to figure out what you have first.
rd400greenhorn
Yeah so there was only one in, the other carb had 'stock' setup..
I might think they miss some stuff so both carbs are off.
What about the tube, as you see in this picture, one carb has it and one dont
You have two left side (choke side) float bowls in the photo above.
Original needle jets should be 175 series. Whatever type you use -- bleed type or primary type -- they should be the same in both carbs.
One carb will have the brass tube and one doesn't. That's normal since you have the choke on one side.
rd400greenhorn
Got cha. Thanks man.
Never messed with original carbs so these info are valuable. I Will get that sorted
