daytona petrol tap
Started by motulman, March 01, 2021, 10:56:17 PM
motulman
has anyone had an issue not getting enough flow through one of these? what did you do? has anyone ever ported a petcock?
If you're worried about fuel starvation, Supertune sells a petcock upgrade using a modified Raptor unit.
motulman
Really? thanks russ, is there a place on here where this item is viewable?
Quote from: motulman on March 02, 2021, 09:31:18 PM
You can find the petock update info in the Tech Library under "Carburetor - Fuel/Air Delivery"
Check your messages, sent you some info.
motulman
thanks russ, chucks idea is a good one i also found out john at econo sells a pingel i flow petcock  although very different in price   thanks for all the help russ
