float height
Started by motulman, March 20, 2021, 02:10:20 AM
motulman
i wanna check my float height on a set of tm 34 mikuni, what is it supposed to be? i cant find shit, i know where to measure from just cant find out what it is supposed to be set to
Mark just rattles this stuff off from memory! :science: (the rest of us have to look it up) LOL
EDIT: I later realized you were looking for TM info, not VM. <smack forehead>
Set the FUEL level and forget about float height.  Yes, changing float height will change fuel level, but what's important is fuel level.  A carb could care less where the floats are or where they should be.  All that counts is fuel level.
shit, my bad. i also 'read' vm.
tms are around 18mm.
Quote from: teazer on March 20, 2021, 04:06:04 PM
I always kinda thought that you set float height to set fuel level.
float height does set fuel level IF its within 15 degree of 'level'(parallel to ground).
While searching for something else I just ran across some Mikuni info for TM float height: 17-19mm for TM32, TM34, TM36
