NGK Spark Plug Upgrade
Started by gardenhosebusabottle, March 22, 2021, 03:56:05 PM
Looks like the BR8EIX is the stock option.  Stick w/ stock plugs or upgrade? Would they be as reliable? Ruthenium plugs are N/A for the RD400.  I can tell you on my 2006 Honda Civic that the Ruthenium plugs idle better, smoother off the bottom and right where the torque curve is, it is a little quicker revving.  I ran a cheap set of G NGK's (interim) and it was terrible...hesitant off the bottom and engine even sounded like it was struggling.
I think I read (especially w/ iridium/Rutheniums), that it should require less spark energy or easier on the ignition.
Ignition is XR700 Fireball (for the RD, NOT the Honda  :haw:).
your opinions/experience?
ive never had issues with regular b9es or b8es. ive run iridiums , had them in the RZ but for no other reason than i just wanted to try them. they are more forgiving against fouling, like leaving the choke on too long, etc, but otherwise no real need.
Thanks Mark,
Will stick w/ the stock plugs.  BTW, those plugs I pulled off the motor I am working on were black on the rim and dark chocolate over everything.  Planning on new XR700 & 3/5 ohm coil.  The other CDI's look like a bit of work...eh the electricals especially.   The fireball works better than the original allison / crane ignition.  On the RD350, it (allison) would "lurch" if you hit a bump...very unsettling while ripping along.  I haven't noticed the "lurch" on the RD400.
