daytona special swingarm
Started by bstream97, April 28, 2021, 03:29:55 PM
bstream97
what other yamahas have the same swingarm as the daytona, not much luck online ,partzilla shows the xs400 same part number , but the first three letters are different (these are model code numbers )   any help thanks .bryan
As far as I know it's like a lot of the other Daytona bits -- one-model-only-parts, not used on any other US models.
However, the same part was used on RD400s in Canada (3J7) in 1979-80, EU (2R8/2R9), and Oceania (3M3/3M4) models.
bstream97
thanks socal, i am thinking about selling my daytona,and seems like stock is bringing more money these days , i will pull my dg swingarm and dg head  before selling, if i can locate a swingarm
Quote from: bstream97 on April 28, 2021, 04:33:07 PM
I'll keep an eye out for you. It seems I saw one for sale somewhere not too long ago, but at the time I wasn't really looking for one so I didn't make a mental note.
What are your plans for the DG takeoff arm? If you're considering selling it let me know.
I found an old post where Mark ("m in sc") said an XS400 arm will swap into a Daytona. Maybe Mark can confirm this is true, even though the part number is different?
RD400F:      2R8-22110-00-33
XS400 E/F:  2L0-22110-00-33
The arms do look very similar. And the rear wheel and axle are the exact same parts. However the pivot shaft looks different and is a different part number.  There's got to be some difference since Yamaha didn't just use the same part number.
99 % its for sure the same. even with the weird ass rear brake hanger etc. Im not aware of any functional or cosmetic differences. even uses the same mags.
zedixe13
I installed a XS360 1976 swing arm on one of my Daytona , it's one inch longer and look better . The rear wheel stay at the same heigh since the shocks are angled and bolted a little bit higher . Just need a new torque arm bracket . Daytona pic on top , XS360 lower .
bstream97
great ,thanks for information.
I know someone who would be very interested in those parts.
ah. so theres a length difference. that makes sense.
stresa
Hi,
I have a couple of european model RD250/400E/F swingarms which are identical to the Daytona one. But I am in Germany.
Regards Uwe
81 Jackson Special 250, 2x 74 Yamaha RD250 racer, 78 Yamaha RD400, 72 R5/RD350 rat, 74 RD250 streettracker, 72 DS7, 75 Yapol TZ250, 89 Honda RS125,
80 Hejira TM250, 77 Höpfner-TD3, 76 RD/TD3,
74 Yamaha TZ/RD250A, 78 Siroko TZ250, Tomic 200, Heideveld RD375 3cyl
Here ya go Bryan: https://www.ebay.com/itm/194123849225
What are your plans for the DG you're removing? :cool:
Plasticman
There are a LOT of parts from the XS400 and other XS models that fit the Daytona.
Rob
1976 - RD400 - road racer
