New project
Started by Jspooner, June 05, 2021, 12:27:24 PM
More to come.
You took the plunge. Can't wait to see where this goes.  :whoop:
Interesting ports.  Is that a 40971? or later?
This is very exciting!
Quote from: teazer on June 05, 2021, 05:20:26 PM
It's a 40971
Please explain those numbers..??
TZ barrels have a number cast into the rear that represents model # 409 and year/ variant
409-70 TZ750 A/B 64mm bore 700cc
409-71 is later 66.25mm full 750cc version and so on
Do you need a base gasket, Joe?
At some point I will need all gaskets and seals.
So for the uneducated this is half a tz750? :umm:
Quote from: teazer on June 05, 2021, 08:52:29 PM
But still the version with 4 transfers, plus boost port? The later versions had 6 transfers, right?
I had a TZ750 cylinder block, and a head, plus a damaged cylinder block for maybe 30 years, but sold them to a guy restoring a TZ750 a couple of years ago. Just never got around to actually use the parts. Part of the reason was that I read somewhere that the TZ crank rotates opposite of an RD or TZ twin crank, and the short intake skirt of the TZ piston  s are not really happy with the side loads when used in an RD. This may be of less consequence than I think, but anyway.
The 1981 TZ250H was the first countr-rotating TZ engine
