84 RZ 350 Deals Gap Prep Begins
Started by Kawtriplefreak, April 10, 2019, 09:10:46 AM
Hopefully all it needs is a transmission oil change and a good scrubbing.
Awsome!!
Change the coolant if using antifreeze if older than 2 years...
Antifreeze stays good at cooling way longer, but the corrosion protection goes bad after 2 years and rots the raw aluminum.
It hasn't been 2 years yet Chuck. Thanks for the tip! :patriot: :patriot:
Thought I was all done
Went for a ride today and postflight discovered both intake rubbers cracked. Will be ordering new ones Monday. Glad I found them. Could have ruined the motor.
time for those 40mm lectrons timmy  :haw: :righteous: :devil: :toot: :science:
Too close to the Gap...I would probably be interrupting your morning coffee :vroom: :vroom:
Disassembly for intake change done. Parts ordered from John at Economy Cycle. Thanks John!! :patriot: :patriot:
Goody box from Economy Cycle with intakes, gaskets and a set of 42.5 pilot jets has arrived... :clap: :clap:
Done and done. Intakes and 42.5 pilots installed. Airscrews at 1.5 Ran most excellent.
