May 17-23
Thread diameter and pitch on front wheel axle nut RD350A
Started by Dvsrd, April 18, 2019, 01:54:44 AM
Hi,
I am planning to buy a TI front axle nut for my XS650 project, and found that the XS nut is M14x1.50.
Now I wonder if the RD axle nut is the same, so I can order 2 at the same time?
And if someone knows the thread diameter and pitch for the RD350 rear wheel axle nut as well, that would be a welcome bonus!
As usual, all these questions pop up when I arrive at work, thousands of km from my garage and bikes....
RD350A/B and RD400C/D (and US-spec E model) front & rear axles are 17mm. I was going to say that the nut should be 17mm like the axle, but I believe it's stepped down so the diamter may be smaller. I would assume the thread pitch would be the same.  I don't have one handy to check.
Quote from: SoCal250 on April 18, 2019, 03:04:55 AM
The XS650 also has a 17 mm axle, so it is likely that the RD has the same nut. Maybe I can look up the part numbers online, and compare.
its a 14mm nut, they swap. i know this because i single point threaded an axle out of TI a few mos ago.  :cheers:
Quote from: m in sc on April 18, 2019, 09:09:01 AM
For an RD? The spine frame bike? And 1.50 mm pitch? (Generic M14 coarse thread is 2.0)
1.5, yup. and yup.
I havent finished it yet, but this is it. I chased it with a stock nut, but a i got a TI nut from a forum member last year and plan on using that. this was a pain, manual lathe, but seemed to come out ok.
Quote from: m in sc on April 18, 2019, 10:40:13 AM
I haven't finished it yet, but this is it. I chased it with a stock nut, but a i got a TI nut from a forum member last year and plan on using that. this was a pain, manual lathe, but seemed to come out ok.
Issues with work hardening while cutting the thread? HSS or carbide bit? (Got a manual lathe in the garage, you see :) )
no, but i made over 20 very small passes. TIN coated insert, very low rpm (like 200), and a LOT of oil.
Quote from: m in sc on April 18, 2019, 11:31:30 AM
Thanks! Excellent info!  If I can get hold of a suitable piece of round stock, I may have a go at machining some TI as well 😊
Found this. Seems kind of expensive, but then I've not priced Ti parts lately ;)
https://racetechtitanium.com/product/yamaha-banshee-titanium-spindle-nut-m14x1-5/
thats actually not bad. $235 for the swingarm pivot though.  :eek:
I found these on Ebay, $17.80 for two.
https://www.ebay.com/itm/2pcs-M14-x-1-5-Titanium-Ti-Hex-Flange-Slotted-Castle-Nut-for-Wheel-Axle-Hub/123730554553?epid=19006868528&hash=item1cceea6eb9:g:13kAAOSwBgtZ2x1T
Yes, I do realize they come from China, but at that prize I can afford to bin them if no good.
They take a 21 mm spanner, so is a bit smaller than the OEM steel nut as well. Which makes them even lighter :)
Had to replace mine as well and I got one at True Value Hardware. If you don't have one, then check an ACE Hardware store.
