Dead RD400 resurrection
Started by JBeasty, April 04, 2022, 03:55:41 PM
0 Members and 7 Guests are viewing this topic.
JBeasty
Thanks Guys. I should know better by now to question the manual if things aren't looking quite right!
1977 RD400
JBeasty
How important is this tab washer/sprocket plate thingy? Other than covering the huge snap ring and providing tabs (nonexistent) to lock the nuts, does it do anythings else? Is there a concern with that snap ring being exposed? I was just going to use washers and lock tight.
Also, I have the 2 Sprocket spacers from Economy on there (for the 520 chain conversion), but there is still a tiny bit of play. Is that normal?
Thanks for any insight.
1977 RD400
not terribly important but if you arent going to run it, run some thin nylocks or something.
or:
https://yambits.co.uk/rd400c-sprocket-lock-tab-rear-p-51906.html
I wouldn't be confident without that snap ring covered. God forbid something snags it.
 It would be my luck.
that snap ring is extremely robust, nothing will snag that and remove it.
Pretty sure that lock plate is made like that to hide the snap ring and make that area look cleaner.
I have a spoked 400 rear hub with a spacer behind the sprocket, so it uses bolts to hold the sprocket on.
last week my bike started making a noise and vibrating just before home. Locking tabs were probably a bit loose and one bolt backed out and demolished the adjuster.
JBeasty
Quote from: rodneya on July 06, 2023, 11:54:01 AMPretty sure that lock plate is made like that to hide the snap ring and make that area look cleaner.
Not sure if you've remedied this, but I have an adjuster I won't be using that you can have.
1977 RD400
Quote from: JBeasty on July 19, 2023, 08:24:02 PM
Thanks for the offer, but I had a spare in my junk bits stash that I managed to get straightened out enough to use.
JBeasty
Has anyone ever fit this VSM6 Airtech seat pan to an RD400? I've got a birthday coming up. Looking for things to put on my wish list.
1977 RD400
svgarage
I purchased a seat that is similar to what you want. My solution was to braze pins to the frame and pin the pan in place. I cut the pins down to size and suspended the seat with rubber stoppers.
A goal without a plan is just a wish.   ~ Antoine de Saint ExupĂ©ry
JBeasty
Very nice! I went ahead and ordered the Airtech seat. I know I'll have to do some sort of fiberglass fabrication to make it work. My hope is to use the stock seat hinges, or some sort of quick release mount - so I can have easy access to the oil tank.
1977 RD400
JBeasty
Made a bit more progress. Rear wheel mounted and centered with spacers I made. Chain lines up nice. Got the front wheel mounted, but I'll have to make another 4mm spacer for the disk, and possibly shim the caliper out a bit, or grind it. As it is, the caliper hits the rim, and the disk does not line up within the caliper.
1977 RD400
