R5 RD350 engine cases
Started by Junr1, June 01, 2022, 08:41:16 AM
Junr1
Picking up R5 engine cases soon. Will all my RD350 internals swap over? Any differences I should be aware of?
Thanks
for the most part all will swap. r5 cases dont have a lip for the crank seal, so you need to use 5 crank seals. also the bearing retainer behind the clutch may be different depending on year. early 73 rd350 might be compatible with r5, later are different. .02
Junr1
