Oh Dear!!
Started by elliottles1, July 11, 2022, 02:35:42 PM
elliottles1
folks,
hoping someone may have some ideas.
out riding my lovely tzr125 when, one by one, components started burning out.
first the koso digital speedo/rev counter, then the digital temp. gauge. (separate component). then the power valve controller.
the bike still runs, so got home, but anything wired to the battery burned. i have tested them separately with a power supply and they are dead. does anyone think that the regulator/rectifier faulted and overcharged? the battery after all this only read 10.5 volts and now wont hold charge, so i may have cooked that.
any ideas anyone (please!)
cheers
les.
oh that sucks.
i would def look at the reg/rectifier
Symptoms of overcharging are one by one dead components. Especially CDI's on old Chrysler outboards. Nothing like floating down the river hoping not to get run over by a freighter, or floating to Canada unannounced lol.
I wonder what would happen with a lithium battery in that situation. Fire in the hole?
bitzz
Does the bike run?
Check the AC voltage across the battery when the bike is running. If you have more than a volt or two, that's your problem.
elliottles1
hi
thanks folks, i now have a plan forwards
les.
elliottles1
folks,
mailed my power valve controller off to this guy today, he has a great reputation, and also modifies the controller to be programmable with various settings, worth checking maybe if anyone has a power valve bike. i was half considering using his services a while ago, and am now convinced that i need them!
https://www.ebay.co.uk/itm/275346366915?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649
cheers
les.
elliottles1
Guys,
i have replaced the burned components including a refurbed ypvs controller. also replaced are the battery with a new one and the regulator/rectifier.
however, when running i get 14.7 at tickover across the battery, dropping to 14.2 when revved, what goes???
the only difference from standard yamaha is the battery which is 3.5amp AGM instead of 5amp lead/acid. could it be that?
thanks for any help/advice.
cheers
les.
14.2 is charging... so, I'd run it.
elliottles1
yup, i will do, but what would cause the voltage to DROP  when revving the bike??
les
the voltage cutout working more efficiently.
elliottles1
thanks folks,
good to go then so.
les.
Not that there is anything in common with your bike but our FZR400 does basically the same thing. It seems to charge like a wounded steer at tickover and as revs rise the R/R cuts it off at a steady 13.5 or so volts.
elliottles1
teazer,
yep, i always thought it should be the other way round. i was a bit concerned because of the blown components with the previous reg/rect. that just cost me a couple o hundred or so. didnt want to blow them again.
cheers
les.
