Calling all vintage smoke rear sets
Started by BCRD, July 31, 2022, 12:37:21 PM
BCRD
I've had my vintage smoke rear sets for my rd400 for a couple seasons now and really like them. The only issue I have with them is the exhaust hanger bushings. They wear out super quick if you take the pipes off a couple times. What are you guys doing as a replacement for these. I've tried countless times to reach out to nick at vintage smoke with no reply. Someone on here mentioned it was possibly a Harley Davidson part. Went to the HD parts counter today and nobody there recognized them let alone seen clear parts on a Harley. I know I'm not the only one with this issue. How do I replace these bushings!
he told me directly it was an HD part. i have no idea what it is though.
maybe buell?
thats all i have.
oxford
Any chance they are a off the shelf part that has been modified?  Google search for HD handle bar bushings show a similar part they just don't have the "key" cut out to interlock with each other.
I also don't have any scale on the part you have vs what I see for the handlebar ones so they may not even be close in size.
I went through this with Smoky Mountain HD. They don't know what they are. They did give me a HD fairing bushing that worked though. It was a direct replacement in one piece. They had to sort through their bushings and I don't have a part number unfortunately.
I only know that it is a fairing bushing for a Harley that I used.
if/when mine ever die, i'll just source a bushing from mcmaster or something.  :twocents:
BCRD
The parts counter guy pulled out HD handle bar bushings and they were not close to the same size.
BCRD
i was literally leaving nick a voicemail (havent heard from him in over 3 yrs) when ^ reply popped up. thats them for sure 100% :cheerleader:
irk_miller
#8
I have these, which are HD grommet hardware. What are the dims?  Is the plastic part of the deal?  That's an odd choice, if so.
not if you knew Nick it wasn't.
fwiw, added a post in the tech section with this info for future reference. thanks BCRD great find.  :cheerleader:
irk_miller
Quote from: m in sc on August 01, 2022, 03:21:50 PM
You can get them with urethane grommets, as well.  Same purpose as the Revzilla listing.  That is just one version of the same hardware.
irk_miller
Sorry to keep adding, but you can get the tophats in aluminum, as well.  Mine are chrome steel, and I've also seen them in stainless.
if i remember correctly, the 'stock' bushings were flat on the sides, making them d shaped, to fit into the slots on his rearsets as well.
BCRD
Not mine. They were exactly as shown in the second picture
