Zeel ignition on my 48H….RZ350
Started by busa1300, August 10, 2022, 05:43:26 PM
busa1300
Ignition gave out on my RZ, when I was getting ready to load it up into my van after a show a few month's ago.
Took some time to feel like looking into the problem, and came to find out the ignition box gave up.
So.... Instead of wasting money on another used 29K-50, I decided to move to the next generation and get a programmable Zeel....and a new coil just for the Hell of it.
Pulled the old stuff out and made a mount for the new bits....just need to get wiring 100% figured before I start making end plugs to hook back up to stock harness.
RZ350-RZV500R-TZR250RSP 3XV2
TS/TM400 supermoto style...
I set my zeel u[p for 35 deg static timing, and when I converted that to mm I realized that most of my dial gauges dont go that far.
busa1300
On the other 3 Zeel ignitions I have put into bikes, I have never set the static timing....
Always just figured it was programmed in and just left them as is.
But now that I think about it, I'm guessing it would be something like setting your TPS, as the program is set to 2 points....and each bike could be a few points off one way or another.
The quick shifter I have set up on my VJ21, I just used the settings already programmed and it works perfect.....Something to look into a little more I guess.
Apparently the RZ I bought a few years ago had the same ignition box failure and the previous owner had a Zeel installed. The wad of wires is something. It works great but some time I have to tidy up the wires.
The '84 L model is known to have an issue with failing CDI boxes due to solder point failures.
i had to do mine on my rz as well way back. the static was spot on, i did check it. also, i bought the correct connectors from vintage connections and made it a direct plug in.  never had an issue out of it.
Economy Cycle John
Quote from: busa1300 on August 10, 2022, 07:42:46 PM
Static timing is where the rotor is physically clocked and is 34 degrees for all RZ's as they are keyed rotors. This needs to be right in the Zeel as it's the baseline for the algorithm to apply the curve, if static timing is wrong, your curves won't be accurate and could have catastrophic consequences.
busa1300
Quote from: m in sc on August 11, 2022, 12:50:51 PM
I'm not finding the connectors anywhere, for the ignition box itself....
i should have been clearer. i replaced both sides.
never going back to stock it didnt matter to me to match the oem ones.
busa1300
 :thumbs:
I always keep all the plugs as factory on my rebuilds, that way it can go back to stock, if that is what the next owner wants....and considering the prices of two strokes are only going up.....everyone approves with uncut/untampered harnesses.
Plus on most of these bikes, I can put the stock stuff back on to check various power valve, TPS, and air solenoid settings.
I have 4 of the 6 correct new connectors, and I now have the correct bullet pins, where I can use the 2 from original ignition box to get all 6 plugs looking original and clean.
Just need to triple check the wiring before I commit.
yeah, i get it but as far as i know, no one is reproducing the stock units with stock plugs. .02
Quote from: m in sc on August 11, 2022, 05:05:47 PM
Ed Toomey is selling a programmable cdi that is advertised as plug and play. Pretty sure it is a Dynatec unit.
Screenshot from his facebook page
digikey or mouser must have them available. that's awesome.
busa1300
#14
Still need to dial in powervalve position, hook up quick shifter and switch for ignition curves (race gas/pump gas)
