Killed another NAPA digital flasher
Started by Kawtriplefreak, September 11, 2022, 12:17:11 AM
Took the RD out for a short romp yesterday and noticed the turn signals stopped flashing about10 minutes into the ride. Another$10 flasher dead. I think the cause for this failure was my utilization of the factory turn signal flasher bracket and a piece of inner tube and tightened the mount up too tight. When I got back to the shop I shut the motor off and was greeted by a loud hum from the flasher unit. I was dreading pulling the tank off to change yet another flasher and decided on an alternative mounting location after cannibalizing a flasher unit off of my 73 H1D parts bike. I went back today and got the flasher grommet and tied it to the RD harness and put the flasher unit in the grommet. Cranked her up and all is well plus I dont have to pull the tank ever again to change a flasher...
switch that to a square one with single mount hole. I mounted mine under the tank to the side of the start relay (cdi ignition).
https://www.napaonline.com/en/p/NF_EP35L
