Kicking myself for not keeping good records 84 RZ350
Started by Kawtriplefreak, December 08, 2022, 08:30:09 PM
I am kicking myself for not keeping good records. I put an R6 cooling fan on my 1st 84 RZ350 and wanted to buy one for my 2nd 84 RZ350. But I didnt write down what year the fan came from. I found a cheap one on eBay for a 99-02 R6 and it is too thick to fit in the space. It has 5 big fan blades whereas the one on my 1st RZ is thinner and has 12 small blades. I am thinking 2003 to 2006 and the ones I am finding in that year range appear to be correct I but am seeking confirmation from someone who knows. Thank you
Pretty sure I read on a thread somewhere that a 06 / 07 fan was installed.
I don't claim to be an expert on this topic as I've never done the fan swap, but looking at the parts fiche and comparing photos it appears these are the 3 common parts:
Early 6-blade, fits 1999-2002 (single fan)
5EB-12405-00-00
7-blade, fits 2003-2005 (dual fans)
5SL-12405-10-00 Left
5SL-12405-20-00 Right
Later 12-blade 10-blade, dual fans, fits 2006 to current (dual fans)
2C0-12405-00-00 Left
2C0-12405-10-00 Right
EDIT - revised fan blade count for 2C0- parts
Thanks. I will count the blades carefully on the one on my white RZ and report back. Looks like 2006 and up.
I replied on the RZ forum also.
08-14 is what I used. 06-07 might be the same.
You may want to consider this upgrade also. Yes, I have subsequently put shrink tube on those lugs. One of the fuses is for the fan. I wired in a manual switch for the R6 fan.
06-up look to be the same part number wise.   :patriot:
its in the 'radiator hose' page of the microfiche
This Yamaha 2C0-12405-00-00 BLOWER fits the following models and components:
Aftermarket Parts Engine Cooling System Cooling Fans
Yamaha Motorcycle 2013 YZFR6 - YZFR6DG RADIATOR HOSE
Yamaha Motorcycle 2012 YZFR6 - YZFR6BL RADIATOR HOSE
Yamaha Motorcycle 2012 YZFR6 - YZFR6BB RADIATOR HOSE
Yamaha Motorcycle 2011 YZFR6 - YZFR6AB RADIATOR HOSE
Yamaha Motorcycle 2011 YZFR6 - YZFR6AL RADIATOR HOSE
Yamaha Motorcycle 2015 YZFR6 - YZFR6FCW RADIATOR HOSE
Yamaha Motorcycle 2016 YZFR6 60TH ANNIVERSARY - YZFR6GCY RADIATOR HOSE
Yamaha Motorcycle 2016 YZFR6 - YZFR6GGY RADIATOR HOSE
Yamaha Motorcycle 2018 YZFR6 - YZFR6JCL RADIATOR HOSE
Yamaha Motorcycle 2018 YZFR6 - YZFR6JCW RADIATOR HOSE
Yamaha Motorcycle 2014 YZFR6 - YZFR6ER RADIATOR HOSE
Yamaha Motorcycle 2014 YZFR6 - YZFR6ECL RADIATOR HOSE
Yamaha Motorcycle 2008 YZF-R6 - YZFR6XB RADIATOR HOSE
Yamaha Motorcycle 2008 YZF-R6 - YZFR6XS RADIATOR HOSE
Yamaha Motorcycle 2008 YZF-R6 - YZFR6XCB RADIATOR HOSE
Yamaha Motorcycle 2010 YZF-R6 - YZFR6ZB RADIATOR HOSE
Yamaha Motorcycle 2010 YZF-R6 - YZFR6ZCB RADIATOR HOSE
Yamaha Motorcycle 2010 YZF-R6 - YZFR6ZW RADIATOR HOSE
Yamaha Motorcycle 2006 R6 - YZFR6VC RADIATOR HOSE
Yamaha Motorcycle 2007 R6 CA - YZFR6WC RADIATOR HOSE
Yamaha Motorcycle 2019 YZFR6 - YZFR6KW RADIATOR HOSE
Yamaha Motorcycle 2019 YZFR6 - YZFR6KL RADIATOR HOSE
Yamaha Motorcycle 2012 YZFR6 - YZFR6BCB RADIATOR HOSE
Yamaha Motorcycle 2013 YZFR6 - YZFR6DL RADIATOR HOSE
Yamaha Motorcycle 2013 YZFR6 - YZFR6DCG RADIATOR HOSE
Yamaha Motorcycle 2011 YZFR6 - YZFR6ACB RADIATOR HOSE
Yamaha Motorcycle 2015 YZFR6 - YZFR6FB RADIATOR HOSE
Yamaha Motorcycle 2015 YZFR6 - YZFR6FL RADIATOR HOSE
Yamaha Motorcycle 2012 YZFR6 - YZFR6BW RADIATOR HOSE
Yamaha Motorcycle 2016 YZFR6 60TH ANNIVERSARY - YZFR6GY RADIATOR HOSE
Yamaha Motorcycle 2016 YZFR6 - YZFR6GL RADIATOR HOSE
Yamaha Motorcycle 2014 YZFR6 - YZFR6ECR RADIATOR HOSE
Yamaha Motorcycle 2017 YZFR6 - YZFR6HB RADIATOR HOSE
Yamaha Motorcycle 2007 R6 - YZFR6W RADIATOR HOSE
Yamaha Motorcycle 2008 YZF-R6 - YZFR6XCL RADIATOR HOSE
Yamaha Motorcycle 2010 YZF-R6 - YZFR6ZCL RADIATOR HOSE
Yamaha Motorcycle 2011 YZFR6 - YZFR6AR RADIATOR HOSE
Yamaha Motorcycle 2018 YZFR6 - YZFR6JCGY RADIATOR HOSE
Yamaha Motorcycle 2018 YZFR6 - YZFR6JGY RADIATOR HOSE
Yamaha Motorcycle 2018 YZFR6 - YZFR6JW RADIATOR HOSE
Yamaha Motorcycle 2018 YZFR6 - YZFR6JL RADIATOR HOSE
Yamaha Motorcycle 2020 YZFR6 - YZFR6L1CO RADIATOR HOSE
Yamaha Motorcycle 2020 YZFR6 - YZFR6L1CL RADIATOR HOSE
Yamaha Motorcycle 2019 YZFR6 - YZFR6KCL RADIATOR HOSE
Yamaha Motorcycle 2019 YZFR6 - YZFR6KCGY RADIATOR HOSE
Yamaha Motorcycle 2016 YZFR6 - YZFR6GCL RADIATOR HOSE
Yamaha Motorcycle 2017 YZFR6 - YZFR6HW RADIATOR HOSE
Yamaha Motorcycle 2017 YZFR6 - YZFR6HL RADIATOR HOSE
Yamaha Motorcycle 2017 YZFR6 - YZFR6HCW RADIATOR HOSE
Yamaha Motorcycle 2015 YZFR6 - YZFR6FCL RADIATOR HOSE
Yamaha Motorcycle 2010 YZF-R6 - YZFR6ZL RADIATOR HOSE
Yamaha Motorcycle 2014 YZFR6 - YZFR6EL RADIATOR HOSE
Yamaha Motorcycle 2014 YZFR6 - YZFR6ECGY RADIATOR HOSE
Yamaha Motorcycle 2012 YZFR6 - YZFR6BCW RADIATOR HOSE
Yamaha Motorcycle 2012 YZFR6 WORLD GP 50TH ANNIVERSARY - YZFR6BGP RADIATOR HOSE
Yamaha Motorcycle 2013 YZFR6 - YZFR6DCR RADIATOR HOSE
Yamaha Motorcycle 2008 YZF-R6 WFLAMES - YZFR6XCY RADIATOR HOSE
Yamaha Motorcycle 2008 YZF-R6 - YZFR6XL RADIATOR HOSE
Yamaha Motorcycle 2011 YZFR6 - YZFR6ACR RADIATOR HOSE
Yamaha Motorcycle 2009 YZFR6 - YZFR6YO RADIATOR HOSE
Yamaha Motorcycle 2006 R6 - YZFR6V RADIATOR HOSE
Yamaha Motorcycle 2006 R6 50th Anniversary - YZFR6SPV RADIATOR HOSE
Yamaha Motorcycle 2006 R6 50th Anniversary - YZFR6SPVC RADIATOR HOSE
Yamaha Motorcycle 2012 YZFR6 - YZFR6BCL RADIATOR HOSE
Yamaha Motorcycle 2012 YZFR6 WORLD GP 50TH ANNIVERSARY - YZFR6BCGP RADIATOR HOSE
Yamaha Motorcycle 2016 YZFR6 - YZFR6GCGY RADIATOR HOSE
Yamaha Motorcycle 2015 YZFR6 - YZFR6FCB RADIATOR HOSE
Yamaha Motorcycle 2015 YZFR6 - YZFR6FW RADIATOR HOSE
Yamaha Motorcycle 2011 YZFR6 - YZFR6ACL RADIATOR HOSE
Yamaha Motorcycle 2014 YZFR6 - YZFR6EGY RADIATOR HOSE
Yamaha Motorcycle 2013 YZFR6 - YZFR6DCL RADIATOR HOSE
Yamaha Motorcycle 2013 YZFR6 - YZFR6DR RADIATOR HOSE
Yamaha Motorcycle 2010 YZF-R6 - YZFR6ZCW RADIATOR HOSE
Yamaha Motorcycle 2009 YZFR6 - YZFR6YCO RADIATOR HOSE
Yamaha Motorcycle 2008 YZF-R6 - YZFR6XCS RADIATOR HOSE
Yamaha Motorcycle 2022 YZFR6 GYTR - YZFR6WNB BN6V RADIATOR HOSE
Yamaha Motorcycle 2017 YZFR6 - YZFR6HCB RADIATOR HOSE
Yamaha Motorcycle 2017 YZFR6 - YZFR6HCL RADIATOR HOSE
Yamaha Motorcycle 2020 YZFR6 - YZFR6L1B RADIATOR HOSE
Yamaha Motorcycle 2020 YZFR6 - YZFR6L1CB RADIATOR HOSE
Yamaha Motorcycle 2020 YZFR6 - YZFR6L1O RADIATOR HOSE
Yamaha Motorcycle 2020 YZFR6 - YZFR6L1L RADIATOR HOSE
Yamaha Motorcycle 2019 YZFR6 - YZFR6KCW RADIATOR HOSE
Yamaha Motorcycle 2019 YZFR6 - YZFR6KGY RADIATOR HOSE
yup, good idea.
i used a derale adjustable unit but same idea, with an over ride switch if for some reason i needed it.
on the lc, used an automotive thermal switch to control the ground, and used an inline temp sensor for the temp gauge. (on the hose above the head, not in pic).  The fan i used was an SPAL though, 4 1/2" I think.
Not sure why an RZ needs a fan, but I just noticed that the hybrid has what looks like a brand new TZ water pump.  Mine are all ground down and scored after sliding up the road with a bike on top of them.
Nice adaptation.  Did you weld up a boss on the side cover for it to sit on?  I had an adapter plate from a kart mounted TZ/RD hybrid that I used on our RD cases, TZ top end and wet clutch drag race motor.
made an adapter out of 6061.
its a total bolt on so i can replace the cover with a stock aircooled one if need be.
thats been on for 18 years, its been slid on once. I bought it from rick mehar back in 04 needing a rebuild.
thanks
as for as an rz needing a fan.. or the lc... they really -dont- but its nice to have in traffic on very hot days. more of an insurance policy than anything.  I think my fan on the lc has kicked in 1 or 2 times ever.
RZ needing a fan? What he said^^^^ You can probably live without it. Normal riding the temperature gauge needle is typically in the middle. They tend to get quite hot if you manage to get into traffic. Also my typical weekend fix takes me from 600 feet elevation to about 4200 feet and sometimes do this in hot weather. The needle will climb a bit going uphill pushing it a bit. Turning on the fan brings the needle back to the middle. Nice peace of mind for me.
That adapter is way more elegant than the three bolt one I used.
Got a fan from a 2012 on the way. Thanks to all for the help. I will also order a new universal manual switch for the LH frame rail under the tank like the one on my white RZ.
Djg8493
If you need any confirmation I have an 05 R6 that I can measure if needed.
