checking timing with timing light
Started by rodneya, May 12, 2019, 12:17:13 PM
If I want to check my RD350 timing with a light do need to set to 1.8mm advanced with a dial gauge and make a new mark above the viewing window? my timing light does not have any advance / retard setting
bracket maker
when the cylinder is ready to fire the timing marks line up. there is a mark at 1.8mm ahead of tdc. you can't see the marks without the strobe light when the engine is spinning. marking the line helps to see it when you flash the strobe. I remove the spark plug on the side I'm checking and run on one cylinder when I'm timing.
there is no advance/retard on any timing light. better ones work on induction, cheap ones work with the ignition voltage. I have the cheap one so I have to remove sparkplugs to time.
HAPPY TO BE HOME, 69-13 FTW,
Redbird
Quote from: bracket maker on May 12, 2019, 06:00:27 PM
Several manufacturers sell timing lights that you can pre-set ignition advance.
I have a Craftsman model in my box as we speak.
yes set to 1.8. if you use a dial back, the chart is in the tech library (mm to degrees)
bracket maker
Quote from: rodneya on May 12, 2019, 12:17:13 PM
why do you think the marks in the timing window are not already set at 1.8mm atdc?
why do you think advance in timing has anything to do with the light and not the points adjustment?
rd350s factory timing marks are set to 2.0mm btdc from the factory.  :twocents:
Quote from: bracket maker on May 13, 2019, 06:55:37 AM
I know for a fact that the mark  on the rotor is not 1.8mm
I never said advance timing has anything to do with the timing light, but if you have that feature on the timing light you can set it and it will flash at TDC
Quote from: m in sc on May 13, 2019, 07:53:08 AM
Thanks M in SC.
Wow, the complete lack of correct or helpful info posted in the answers is amazing.
to be more on point, yes. verify your marks are at 2.0. use chart, set dialback light where you need it (1.8) and time with a light.  :cheerleader:
bracket maker
that's not the point. why does the op feel he needs an advance on the timing light to set the timing?
why does the op feel the timing marks set at the factory are wrong?
the timing light strobe does not adjust timing it only allows you to see the timing marks in real time when the engine is running. why would a timing light have adv/retard built in? how would this even be possible, mm to degrees is a complicated formula dependent on stroke and rod legnth. how could you even enter this info into a light?
because you can use tdc timing marks with a dialback timing light to set it where you want to. I set my cars using the tdc mark and change the offset in the light to reflect initial advance, then total advance when i rev it out to.  I also set up my cdis in the bikes with programmable curves using one mark as well that way, OP is on the right track. so, you can throw a timing light on the rd at tdc mark (you have to make that). then set the dial back to where you need it ( i linked the chart) .
but  to the ops post, yes, make new marks if you dont have a dialback. easy as pie.
bitzz
Quote from: rodneya on May 13, 2019, 10:42:57 AM
Welcome to the internet.
New here?
bracket maker
dialback timing light, man I'm fucking old. mine is neon to boot. I just do it live and make my own marks when I need.
i have a self powered neon one as well. theres a bunch of ways to skin a cat, the dialback is not expensive and a real time saver if oyu work on a lot of vehicles.
