Handlebar controls,...Suggestions on brands / sourcing
Started by suey1958, May 14, 2019, 11:25:20 AM
suey1958
Still collecting parts for the rd350 bare bones project so now looking for handlebar stuff: throttle control, master cylinder, clutch perch, levers etc.
Not looking for original controls and parts,... just the bare minimum.
Any brands / sources that anyone can recommend would be appreciated. Thanks
THERES A POST ABOUT MASTER CYLS that covers the brake side.
me? i like the r6/ninja clutch lever and perch with the spring retainer on the adjuster.  https://www.ebay.com/itm/03-05-06-09-Yamaha-Yzf-R6s-Clutch-Perch-Mount-With-Lever-/282813265570
as far as throttle ive used the cheapie motion pro ones up to a pricey domino twin cable unit. using stock carbs and oil pump or? or, use a repop xs control.  you can use the start as a horn button. https://www.mikesxs.net/yamaha-xs650-bar-switch-brake-side-black-76-78-oem-584-83963-00-00.html
