Dial indicator question
Started by Aloha808, April 22, 2023, 04:01:15 PM
Aloha808
I have a new dial indicator from Economy Cycle.
Can anyone tell me how to put an extension on.  It looks like I just need to unscrew the bottom cap and screw back on the extension.  If that is the case, then that cap is on real good.  Any suggestions on how to do this without damaging the dial gauge?
Thanks
Economy Cycle John
yes it unscrews there, it's just tight. Use something to get a better grip on it or gently use some pliers on it.
Aloha808
Thanks John/Economy Cycle for the quick response.  I should of just emailed you guys direct.  Didn't think about that until after.
Anyways, Thanks again!
kramdua
yes i used economy cycles dial and i wondered the same thing. just a little turn with a set of pliers and your good to go.
8 year absent.
back in action.
virginia.
