Headlight Assembly
Started by bheezy27403, May 10, 2023, 02:31:23 PM
bheezy27403
Specifically the grommet/dampener and bolts that hold it to the ears. I put on some clipons (hate them but it does keep the front wheel down better) and did a stint down the hwy @ 80 for 5 miles or so. When I got around to replacing the choke lever that night I noticed the bucket just hanging there. Can I get a link to a place to purchase said parts? I'm having trouble finding them. Thank you in advance.
Guessing this is for your RD350A you've mentioned in the past?
I believe this is what you're looking for:
https://www.economycycle.com/shop/yamaha-rd250350400r5ds6ds7-parts/frame-related/rubber-parts/yamaha-rd-headlight-mounting-kit/
The headlight is fastened into the ears with the threaded rods on the turn signal stalks. If you've removed the OEM turn signals you'll just need to get some appropriate bolts with nuts & washers from the hardware store.
bheezy27403
Yessir. Thank you my friend. Cheers!
