Front Brake Lever
Started by Milan, June 06, 2023, 11:13:07 AM
Milan
This lever was on one of the bikes that I purchased.
I have since removed it, and went back to stock, as it hit the gauge cluster.
Seems to have some sort of adjustment dial on it.
I probably wont be installing it, so if anyone has a use for it.
M
the whole master cyl? whats the bore diameter, i might be interested.
Milan
Im not sure what the bore would be.
I would have to take it apart, unless there is another way to tell.
i will look for some part numbers on it tonite.
oxford
Bore size should be marked somewhere on it.
The dial is for the lever throw.
Milan
I checked all around it, and there are no markings.
M
ok. how did it feel w the stock tzr caliper? too stiff, or good? (just not stock)
Milan
It felt pretty good while on the TZR, maybe just a bit stiff.
It did hit the gauges when turning left.
But may be fine on other bikes.
But that may just be my preference, for a softer feel.
M
probably a 14 then. what you looking for it?
Milan
I would prefer not to have to stash it away somewhere, and find it then in a couple years.
probably just postage to send it.
M
