Steering head bearings
Started by dgorms, June 26, 2023, 06:31:09 PM
What's the general consensus on steering head bearings for an R-5? Mine are shot.
For years the common go-to has always been the tapered set from All Balls Racing, however there are complaints that even when properly installed there is a resulting gap because they are slightly thicker.
Economy sells caged bearing sets if you want to stick with balls. I bought some a while back but haven't installed them yet.
And lastly the OEM balls & races are still available but they're super expensive! Each ball is about $6 and there are 38 of them. :eek:
You can go with tapered roller for the lowers, which receive most of the abuse and notchyness. You can stay with balls for the uppers.
irk_miller
Quote from: SoCal250 on June 26, 2023, 09:48:57 PMFor years the common go-to has always been the tapered set from All Balls Racing, however there are complaints that even when properly installed there is a resulting gap because they are slightly thicker.
I get them at McMaster-Carr.  A pack of 100 is just under $6.  HVC sells a pack of 38 for $15.50.
