login not working from India
Started by Pravin, August 17, 2023, 09:00:40 AM
Pravin
hello Admins,
I am not able to login from India to 2strokeworld.net , but my login works from UK and USA. can this be fixed please.
I'll release the geoblock for your country, but if the bots start rolling back in again like they were, I'll reinstate it.
Just looked in there, not blocked on my end. Something on your side, ISP server, something, but its wide open here.
Pravin
Hi SC ,
I got this new laptop and am still facing same issue , attached is the error. I just happen to try express VPN and selecting UK as location to connect and am in : )
I feel something to do with whitelisting ? Good to be back in after so long for a month atleast untill the free trail expires..
Can you please check if there is anything to rectify ? I cant access on mobile also using 2 service providers : (
Cheers,
Pravin
Gil Gallad
i'm still getting the same, but only on my laptop. if i don't log out i get this same message and have to log out - then it goes normal, then log in again. if i do log out i just have to log in and everything ok. weird, but true  :eek:
cheers, gil.
p.s. on the p.c. it's fine, just this bloody laptop.
pm me your ip address and email address. nothing is geo blocked
Pravin
Hi SC ,
I have pinged you my IP and Email , let me know when i can try without VPN : )
Cheers,
Pravin
Pravin
Quote from: Gil Gallad on December 26, 2023, 07:52:49 AMi'm still getting the same, but only on my laptop. if i don't log out i get this same message and have to log out - then it goes normal, then log in again. if i do log out i just have to log in and everything ok. weird, but true  :eek:
cheers, gil.
I tried with edge and Firefox and still same , not i tried a VPN and connected to uk on my cell and it's working .
Does it has to do with the website provider ? I am quite sure some where the ips are blocked not at the website admin level but at the provider level ?
Any network expert here ?
Cheers
Pravin
Pravin
I am able to access the forum now without VPN ... thanks a lot !!
was a block buried via a proxy ip address.glad it's smoother for you now, sorry about that.  def NOT my area of expertise BUT I stumbled thru it
Pravin
Quote from: m in sc on January 24, 2024, 07:53:58 AMwas a block buried via a proxy ip address.glad it's smoother for you now, sorry about that.  def NOT my area of expertise BUT I stumbled thru it
Super !! Thanks a lot Sir  :)
