Base gasket
Started by dgorms, December 14, 2023, 07:18:17 PM
I know this has been addressed, but do you use any sealant on RD 400 base gaskets?
Quote from: dgorms on December 14, 2023, 07:18:17 PMI know this has been addressed, but do you use any sealant on RD 400 base gaskets?
I don't
bitzz
I put grease on then, in the hope they come apart cleaner
anaerobic sealer is a good option as well. https://www.permatex.com/products/gasketing/anaerobic-gasket-makers-sealants/permatex-anaerobic-flange-sealant-50-ml/
it also comes right off for disassembly. great for intakes (reeds etc) as well.
Quote from: bitzz on December 15, 2023, 09:30:02 AMI put grease on then, in the hope they come apart cleaner
I do this as well, but no sealant.
Gil Gallad
just a smear of grease on each face works for me. no more ripping them in half when you remove the barrels and mine have never leaked  :guinness:
cheers, gil.
Pravin
Yes grease on both sides and done ..
rearwheelslider
Grease for me. Unless the contact surfaces are roached. Then I go with high tack spray.
1982 CB900F
2008 Speed Triple 1050
2001 CR250R
