Manifold w/ boost port
Started by STLMike, August 09, 2024, 10:51:46 PM
STLMike
Making a little more progress on the RD350 rebuild. Manifold rubber is cracked so I need to replace. Might as well replace with the crossover tube. I'll be running VM30 carbs. Economy has moose racing brand that show they fit 30mm carbs. I'm also seeing OEM Banshee manifolds with the port. I could save money going the banshee route but unsure if they will fit the VM30's. Anyone with experience with this?
2t Fan
Banshee carbs are VM26 right . So you may need moose racing manifolds i think
The Banshee/RZ350 manifolds will fit 26 or 28mm carbs but if you're jumping up to 30mm you'll need aftermarket manifolds like Moose or UPP designed for the larger spigots.
STLMike
I've got Moose Manifolds on the way.
