RD 350 Stock Carbs
Started by 2 Smoker, October 01, 2024, 11:58:41 AM
2 Smoker
Question is this, should I run my stock carbs with the Dave F mod or replace with new carbs. Engine is stage II port with stock cages with TDR reeds. :umm:
I am biased. But I love the TM32s I put on my (stock porting with chambers and Vintage Smoke igntion) 75RD350B. They made a huge difference in performance and driveability.
check my cheap carb thread.  or the tms. stock carbs Will work fine as well and can retain y boot if you are inclined
2 Smoker
Quote from: m in sc on October 01, 2024, 02:15:27 PMcheck my cheap carb thread.  or the tms. stock carbs Will work fine as well and can retain y boot if you are inclined
Thank you for the feed back
2 Smoker
I do not plan on retaining the stock air box.
I will also be installing the Vape ignition and a
Rebuilt crank
yeah the pwks will do well thrn
2t Fan
may I know PWK28 model no which has air screws outside which are easily accessible
they are going to be on the LH side for the most part. get a long screwdriver.  you can get to them. they should have to be fiddled with much f at all after its dialed in.
2t Fan
found it, splatshop.co.uk is selling customized PWK.s with airscrew either in right or left side
are you talking about the SLIDE (idle) SCREW or the AIR screw? big difference. I mod mine to put the idle screw on the left and right, its just an m5 drill and tap and an M5 plug screw. takes like 10-15 mins.  but, that's not the air screw.   :twocents:
2t Fan
#10
Quote from: m in sc on October 05, 2024, 12:37:07 PMare you talking about the SLIDE (idle) SCREW or the AIR screw? big difference. I mod mine to put the idle screw on the left and right, its just an m5 drill and tap and an M5 plug screw. takes like 10-15 mins.  but, that's not the air screw.   :twocents:
oops! i thought its the airscrew, my bad   :umm:
its fine but was wondering because the air screw would require a left and right casting difference.
