new points
Started by elliottles1, April 08, 2025, 05:03:54 AM
elliottles1
guys,
a question that i should be able to get my head around, but cant.
if i replace a worn set of ign points with a new set, assuming the points gap is the same, does the ignition timing stay the same??
cheers
les.
elliottles1
the heel wears. also mfg variances.
klaird
Take your time when setting the ignition timing the point plates tend to move quite a bit when you tighten them down.
