cheap solution to my potential bad coil
Started by bracket maker, July 01, 2019, 09:38:10 AM
bracket maker
I read your thread on how to wire a motorcycle. I saw that you posted on the thread about a  b108 universal ignition and how that could be a cheap solution to my potential bad coil on my RD350. Obviously it needs a custom mount but is everything pretty much straight forward with that coil? I have a set of EMGO coils that I believe one of them may be on its way out.
the emgo coil I tried first did not work. bought it on ebay with the search '12v points ignition coil'. had a sentra coil from a car I owned. no issues for the 3 years I rode on it. emgo has mixed quality. some of their products are fine. others suck.
80's coil packs rock. posted the b108 coil because the thing has an external resisor. you will need it with an rd. coils wire exactly the same. the only issue is the connection to the spark plug wire. ultra black is an easy way to form silicone insulators. be creative. better than new for cheap. this coil pack is for a vw dune buggy.
If the emgo wire and cap are in good condition you can cut them off and use them on the new coil.
thanks for reading my post.
HAPPY TO BE HOME, 69-13 FTW,
