1974 RD350 - Changing Exhaust from DG to Stock, What to expect
Started by KANDY, May 01, 2025, 09:42:13 PM
KANDY
Hi All,
Planning to change the exhaust from DG Pipes to Stock.
The Cylinder is ported as per previous owner and bottom end power is less, picking up at 4500 to 5000 RPM Top end is Strong. Running on Y-Boot with K&N. The Question is What I should expect once I do this change. Changing because - Like the Stock Look.
1974 RD350
1981 RD350LC
1977 RD400
1980 RD400 Daytona Special
itll gain some bottom end back im sure, jetting needs to change  a bit and it will def be better. TBH id run stock pipes over dgs any day . expect the power to die off before 9k
KANDY
1974 RD350
1981 RD350LC
1977 RD400
RDnuTZ
I'm going to give those improved baffles from Yambits a try. In process getting my 350 back together and will run stock pipes to go get it inspected and registered before modding.
1977 RD400 (Project)
1974 RD350 (2) (Projects)
1973 RD250 (Project)
