Gray Ghost 421
Started by Kawtriplefreak, June 06, 2025, 07:04:32 AM
0 Members and 30 Guests are viewing this topic.
PWKs disassembled. 160 Mains, 50 Pilots, CEL needle in middle clip
Cleaned up top case. Threads chased. Bolts installed in all the holes. Clutch arm hole plugged. Bead blasted, blown clean and wiped down with acetone.
Simmons1
Slowly but surely. Next step is bake at 250 in the shop oven for an hour to get all the petroleum residue out of the metal. Then another acetone wipe down with a tack cloth and shoot some paint while it is still warm. Then, back in the oven at 200 for two hours.
Love seeing the progress and all the goodies arriving. Quite inspiring. :olaf: It's giving me motivation to keep my stuff moving, just to attempt to keep pace
On my last build the White RZ I bought a large metal hole saw and spent about 3 days drilling and shaping with a hand file and got a good job on the clutch cover window. And honestly I was dreading it this time around. I recently purchased some carbide Dremel cut-off wheels from Walmart of all places thier store brand and 45 minutes later all that is left to do is a little clean up with a half round hand file and it will be done. I can't believe how good this worked and very cheap as well. It was tedious but easily accomplished by cutting out the center portion vertically and then shaving down the remainder. All this was done with one cutoff wheel with a flex shaft Dremel.
Thanks Fellas. I sure hope so...
i think you should chrome plate the cover.  :nana:
I was thinking Pepto-Bismol pink.
pink flames on the chrome with ghost skulls at the flame tips.  :metal:  :haw:
And a House of Haase Hare decal... :vroom:  :vroom:
About 25 minutes with a half-round hand file and I am calling the window in the clutch cover done. Next step is to chase all the threaded holes, install bolts in them and it's off to my bead blast machine.
Threads chased in all the holes. Bolts installed. Bead blasted and wiped down with acetone. Ready for the shop oven.
