Mikuni TMX34 carbs on RD350
Started by 350GUY, September 20, 2025, 07:23:11 PM
350GUY
Has anyone tried mounting the TMX34 (Skidoo) carbs on the RD350? Seems like the are quite tall in terms of height and I suspect that the float bowl might hit the engine case. Has anyone tried these?
TIA
Here's some pics of VM34s on my 400 to show how much room there is for them. Plenty of room for the bowls and maybe you can gauge how much taller the TMs are.
350GUY
Quote from: 1976RD400C on September 21, 2025, 11:35:55 AMHere's some pics of VM34s on my 400 to show how much room there is for them. Plenty of room for the bowls and maybe you can gauge how much taller the TMs are.
A very many thanks, very helpful. Seems like the TM series are much taller. I've snagged this from e-bay.
https://ebay.us/m/ynO8Ly
350GUY
Snagged this from Ebay
going to be very tough to get air filters on , the 350 frame is narrower there.
Yes, the 400 has almost 6" between the frame rails so you can cram a pair of foam filters in there but the 350 only has 4".
BTW my cylinders have had lots of work done to the transfer ports and the reed cages are modified RZ sized with single petal reeds. That's why the big carbs.
Billet Banshee intakes move the carbs back and up. Just make sure you buy from a reputable seller with genuine mikuni intake flanges and not chinese knockoff stuff. Thats not a place you want a leak.
I have a RZ motor in my 73 350 with TM34 carbs and I use a Ramair sock filter due to serious lack of space. I just stretch the openings over the carbs and it has stayed in place so far.
Screenshot 2025-09-21 at 18-03-38 2x Twin Inlet Motorcycle Carb Sock Foam Air Filter 72mm (2.8inch) - Ramair Filters Inc.png
this is exactly why I had a custom y boot printed i designed.
350GUY
Quote from: rodneya on September 21, 2025, 09:07:44 PMBillet Banshee intakes move the carbs back and up. Just make sure you buy from a reputable seller with genuine mikuni intake flanges and not chinese knockoff stuff. Thats not a place you want a leak.
Thanks Rodney, I might have to get these RAM air filters. I like Marks custom Y boot.
350GUY
Quote from: m in sc on September 21, 2025, 09:41:23 PMthis is exactly why I had a custom y boot printed i designed.
Thanks Mark. This would be the solution. Will now need to figure out the specs of the Y-boot....
steve burgess (3d unobtanium) out of the uk has the model and i ok'd him to sell them in my design. if the bellmouth is the same diameter as a TM34, it will work. its fuel proof and flexible enough to work.  0.02
irk_miller
I've been running a custom TPU 3d printed intake on my Honda Elsinore for well over a year. It goes through hare scramble hell and it works great.  I've also been using the Ramair filters with my TM34's and they also work great. The Ramair filter has more surface area than running a single filter through a wye and keeps everything inside the cradle, which is why I swapped to the Ramair. I've also printed an exe intake to run dual filters. I never properly flow tested anything, so can't say for certain if any setup is better than another. so went with the simplicity of the Ramair.
no motor on here here is going to ever going come close to outflowing a 75mm ID Y boot, w 56/58mm id runners. ever. It's not about area, its about smoothing & directing the air flow,  or i would have stuck with my all-foam unis i had on as well. it def runs better w the Y on there. IF there was room i would have just made 2 straight runners but that damn frame. lol.  However, the difference was not night and day  over all, the foam filters are really good. Yes, i even have an all foam ram air setup like that as well.
irk_miller
Quote from: m in sc on September 28, 2025, 10:23:58 PMno motor on here here is going to ever going come close to outflowing a 75mm ID Y boot, w 56/58mm id runners. ever. It's not about area, its about smoothing & directing the air flow,  or i would have stuck with my all-foam unis i had on as well. it def runs better w the Y on there. IF there was room i would have just made 2 straight runners but that damn frame. lol.  However, the difference was not night and day  over all, the foam filters are really good. Yes, i even have an all foam ram air setup like that as well.
When it comes to a filter, it's absolutely about surface area. That's a ridiculous statement.  Your wye works well because of it's large interior dimensions, not the shape or some flow it creates.  You want intake air to be pretty much ambient, unless you're creating a forced air situation like with a turbo.
