Gear Shift lever
Started by 350GUY, November 02, 2025, 10:42:31 AM
350GUY
Hi All: Is there any alternate gear shift lever that is a direct fit on the RD350 gear shift shaft? Has anyone tried the YZ125 shift lever? The shaft size seems to be same as of the RD based on the oil seal dis.
Long story short, the belly of my exhaust pipes are huge and not tucked under the frame. The OEM lever tends to hit the side of the belly interfering with down shifting....
Quote from: 350GUY on November 02, 2025, 10:42:31 AMHi All: Is there any alternate gear shift lever that is a direct fit on the RD350 gear shift shaft? Has anyone tried the YZ125 shift lever? The shaft size seems to be same as of the RD based on the oil seal dis.
Most all Yamaha levers, including XT250&500, XS650 will fit. And some Honda as well
yup. lots of tusk mx ones fit. also xs650 ones can be had, you can bend them pretty easy as well
350GUY
Thanks guys, this is helpful.
Aaron Russell
For a while i had a yz250 shifter mounted backwards on my 400
