Tire pressure question
Started by rdsarefun, July 07, 2019, 05:35:42 PM
rdsarefun
After a search thru the site with no hits, I was wondering what tire pressures you guys use.  My bike is a restored 73 Rd350 that has stock suspension and original size tires. I don't have my FSM with me at present as I am currently on vacation and am relaxing drinking some beers in the sun.  I think a lot has to do with rider weight but wanted some feedback from user group.
Thanks, Brian
30psi when hot is a pretty good baseline
Redbird
Assuming the vehicle (car or bike) is running the OEM size tire, I always start with what the manufacturer recommends for tire pressure, and adjust accordingly from there.
Generally the vehicle manufacturer will be a better judge of what pressure the vehicle should run. Tire manufacturers only state what the max psi their tire can safely operate with. Those two numbers are usually very different.
evansje1
1973 RD350 2014 Suzuki D1000 1979 RD400 1984 RZ350
