VM28-418 flat slides on RD350.
Started by IR8D8R, April 16, 2026, 12:25:23 PM
Does anyone have the VM28-418 flat slides on an RD350?
I got a pair for a good price.
 Supposedly these are a replacement for the OEM VM28. I don't know why they use the VM designation on these or if/how they differ from a TM28.
What emulsion tube and needles should I use?
Is there a particular air jet size? I have the Dave F mod on my stock carbs so I presume the jetting will be different.
The bike has a PD/Vape, FPP chambers, Chuck Q. Harry Barlow boost bottle on RZ manifolds, YZ 125 fiber petals on stock reeds, and stock port timing.
Spec on these say the spigots are 33 mm. Stock is 32? Any problems mounting?
Will these use the stock throttle cables or do I need to buy new cables? No oil pump. I was considering a Domino dual-cable throttle.
Thanks!
